Ga door naar hoofdinhoud
Samsung Galaxy Camera Lens and Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: stap 1, afbeelding 1 van 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Camera Lens and Motherboard Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Camera Lens and Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently pull the connector away from the motherboard.
    Help! I can't get this connector back in place! How did you do it?
    Thanks!
    rotraut geringer - Antwoord
    Got it finally - and it's working again, I can't believe it! Thank you so much for the instructions!!!!
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: stap 7, afbeelding 1 van 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
    This seems to be wrong. Only 2 screws connect the lens to the camera body - if you unscrew the others, you open up the lens and there is no need to do so.
    NOVOMOTION J. H. - Antwoord
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard and lens out of the case.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Richard Hicks
1.280 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Winter 2015 Lid van USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Leden
1Gids Commentaar
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 5,210
