Wat je nodig hebt
Switch off your phone.
Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
Remove the 12 Ph00 screws holding the midframe
Remove the sim and sd card trays
Using a plastic pick start opening the midframe starting from below the volume buttons going up and around the phone
remove the 2 mainboard (one below the antenna cable and headphone jack screws.
Detach and unchannel the antenna cable from the USB board
Carefully lift the mainboard and pull out the USB board
To reassemble your Samsung Galaxy A5 2015, follow these instructions in reverse order, adding tape where needed.
Één andere persoon heeft deze handleiding voltooid.
