Inleiding
Use this guide to replace the back cover of your Galaxy A5.
Wat je nodig hebt
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift the back cover to insert an opening pick.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Insert a plastic card at the bottom and slide it underneath the back cover.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
26 andere personen hebben deze handleiding voltooid.
