Ga door naar hoofdinhoud
Samsung Epic 4G Touchscreen Replacement
Wat je nodig hebt
    1. Samsung Epic 4G Touchscreen Replacement, Phone Case: stap 1, afbeelding 1 van 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Touchscreen Replacement: stap 2, afbeelding 1 van 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Battery: stap 3, afbeelding 1 van 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Memory Card:: stap 4, afbeelding 1 van 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: stap 5, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: stap 5, afbeelding 2 van 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: stap 6, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Micro USB Port: stap 7, afbeelding 1 van 1
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: stap 8, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: stap 8, afbeelding 2 van 2
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: stap 9, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: stap 9, afbeelding 2 van 2
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Epic 4G Touchscreen Replacement: stap 10, afbeelding 1 van 1
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Camera Lens: stap 11, afbeelding 1 van 1
      • Remove and replace the camera lens with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Keyboard: stap 12, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Keyboard: stap 12, afbeelding 2 van 2
      • Remove the white label sticker.
      • Remove the four screws on the left side of the device with a small Phillips screwdriver.
      • Two of the screws are found behind the white label, and two are found directly above the label.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Touchscreen Replacement: stap 13, afbeelding 1 van 3 Samsung Epic 4G Touchscreen Replacement: stap 13, afbeelding 2 van 3 Samsung Epic 4G Touchscreen Replacement: stap 13, afbeelding 3 van 3
      • Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
      • Carefully remove the gray mid-plate with the spudger.
      • Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
      • The mid-plate should be completely removed from the keyboard and separated from the device.
      • At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: stap 14, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: stap 14, afbeelding 2 van 2
      • Remove the four Phillips #00 screws on the keypad housing.
      • Carefully pull off the keypad housing while avoiding the flex cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: stap 15, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: stap 15, afbeelding 2 van 2
      • Remove the two black screw covers using the spudger.
      • Carefully unscrew the four corner screws using the Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: stap 16, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: stap 16, afbeelding 2 van 2
      • Pry off the slide mechanism using the flat edge of the spudger.
      • Be careful not to push the spudger too far in since it can damage the phone.
      • Carefully separate the slide mechanism while avoiding the flex cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: stap 17, afbeelding 1 van 3 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: stap 17, afbeelding 2 van 3 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: stap 17, afbeelding 3 van 3
      • Carefully remove all the blue tape using the tweezers.
      • Unsnap and pull out the large portion of the flex cable.
      • Pull off the front face camera using the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: stap 18, afbeelding 1 van 3 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: stap 18, afbeelding 2 van 3 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: stap 18, afbeelding 3 van 3
      • Carefully pull out the smaller portion of the flex cable using the tweezers.
      • Pop out the last part of the flex cable using the flat edge of the spudger.
      • Remove the flex cable completely.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: stap 19, afbeelding 1 van 3 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: stap 19, afbeelding 2 van 3 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: stap 19, afbeelding 3 van 3
      • Pull out the touch sensor flex cable using the tweezers.
      • Fold back the strip of white tape using the tweezers.
      • Pop out the speaker assembly using the spudger.
      Vraag FixBot
      Voeg opmerking toe
    7. Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: stap 20, afbeelding 1 van 2 Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: stap 20, afbeelding 2 van 2
      • Carefully pull apart the frame and the screen.
      • You can now replace the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrew Cunningham
273 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-25, Regan Fall 2012 Lid van Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Leden
49 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 5,479
