Ga door naar hoofdinhoud
Samsung Epic 4G Power Button Replacement
Wat je nodig hebt
    1. Samsung Epic 4G Power Button Replacement, Phone Case: stap 1, afbeelding 1 van 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Power Button Replacement: stap 2, afbeelding 1 van 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Power Button Replacement, Battery: stap 3, afbeelding 1 van 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: stap 4, afbeelding 1 van 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: stap 5, afbeelding 1 van 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: stap 5, afbeelding 2 van 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Power Button Replacement, Removing the Power Button: stap 6, afbeelding 1 van 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Cunningham
273 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-25, Regan Fall 2012 Lid van Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 2,760
