Ga door naar hoofdinhoud
Samsung Epic 4G Camera Lens Replacement
Wat je nodig hebt
    1. Samsung Epic 4G Camera Lens Replacement, Phone Case: stap 1, afbeelding 1 van 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Camera Lens Replacement: stap 2, afbeelding 1 van 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Camera Lens Replacement, Battery: stap 3, afbeelding 1 van 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Camera Lens Replacement, Removing the Memory Card:: stap 4, afbeelding 1 van 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: stap 5, afbeelding 1 van 2 Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: stap 5, afbeelding 2 van 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: stap 6, afbeelding 1 van 2 Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Camera Lens Replacement, Micro USB Port: stap 7, afbeelding 1 van 1
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: stap 8, afbeelding 1 van 2 Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: stap 8, afbeelding 2 van 2
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: stap 9, afbeelding 1 van 2 Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: stap 9, afbeelding 2 van 2
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Epic 4G Camera Lens Replacement: stap 10, afbeelding 1 van 1
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Epic 4G Camera Lens Replacement, Camera Lens: stap 11, afbeelding 1 van 1
      • Remove and replace the camera lens with a new one from a manufacturer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Andrew Cunningham
273 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-25, Regan Fall 2012 Lid van Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 1,442
