Inleiding
This guide will show how to remove the camera's lens.
Wat je nodig hebt
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the blue button control from its position next to the LCD screen.
Pull the ribbon cable to disconnect the blue button control from the camera.
Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
Remove the circuit board cover
7 andere personen hebben deze handleiding voltooid.
