Ga door naar hoofdinhoud
Samsung Chromebook 3 Daughterboard Replacement
Wat je nodig hebt
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: stap 2, afbeelding 1 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 2, afbeelding 2 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 2, afbeelding 3 van 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: stap 3, afbeelding 1 van 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: stap 5, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: stap 7, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: stap 7, afbeelding 2 van 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: stap 8, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: stap 9, afbeelding 1 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 9, afbeelding 2 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 9, afbeelding 3 van 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: stap 10, afbeelding 1 van 2 Samsung Chromebook 3 Daughterboard Replacement: stap 10, afbeelding 2 van 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: stap 11, afbeelding 1 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 11, afbeelding 2 van 3 Samsung Chromebook 3 Daughterboard Replacement: stap 11, afbeelding 3 van 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: stap 12, afbeelding 1 van 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sarah Westberg
23.143 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 1,188
