Ga door naar hoofdinhoud
Samsung Captivate Camera Assembly Replacement
Wat je nodig hebt
  1. Samsung Captivate Camera Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Captivate Camera Assembly Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on the bottom of the battery and lift to remove.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Captivate Camera Assembly Replacement: stap 3, afbeelding 1 van 1
    • Replace the old battery with the new one.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Captivate Camera Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 4.5mm #000 Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Captivate Camera Assembly Replacement: stap 6, afbeelding 1 van 3 Samsung Captivate Camera Assembly Replacement: stap 6, afbeelding 2 van 3 Samsung Captivate Camera Assembly Replacement: stap 6, afbeelding 3 van 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Captivate Camera Assembly Replacement: stap 7, afbeelding 1 van 1
    • Separate the rear case from the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: stap 8, afbeelding 1 van 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Captivate Camera Assembly Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the camera assembly out of the plastic housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Drew Bentz
565 Reputatie
5 handleidingen geschreven
Cal Poly, Team 20-25, Maness Fall 2011 Lid van Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Leden
18 handleidingen geschreven
2Gids Commentaar
Is this for the front facing camera
tracy mann - Antwoord Deel
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 36
Altijd: 2,798
