Ga door naar hoofdinhoud
Samsung BD-JM57C Open Button Replacement
Wat je nodig hebt
  1. Samsung BD-JM57C Open Button Replacement, Top Cover: stap 1, afbeelding 1 van 2 Samsung BD-JM57C Open Button Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Open Button Replacement, Disc Drive: stap 2, afbeelding 1 van 2 Samsung BD-JM57C Open Button Replacement, Disc Drive: stap 2, afbeelding 2 van 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Open Button Replacement: stap 3, afbeelding 1 van 2 Samsung BD-JM57C Open Button Replacement: stap 3, afbeelding 2 van 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Open Button Replacement, WiFi Card: stap 4, afbeelding 1 van 2 Samsung BD-JM57C Open Button Replacement, WiFi Card: stap 4, afbeelding 2 van 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Open Button Replacement, Power Cord: stap 5, afbeelding 1 van 2 Samsung BD-JM57C Open Button Replacement, Power Cord: stap 5, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Open Button Replacement: stap 6, afbeelding 1 van 1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Open Button Replacement: stap 7, afbeelding 1 van 1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Open Button Replacement: stap 8, afbeelding 1 van 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  9. Samsung BD-JM57C Open Button Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  10. Samsung BD-JM57C Open Button Replacement: stap 10, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  11. Samsung BD-JM57C Open Button Replacement: stap 11, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
  12. Samsung BD-JM57C Open Button Replacement, Open Button: stap 12, afbeelding 1 van 1
    • Locate the Open Button on the circuit board.
  13. Samsung BD-JM57C Open Button Replacement: stap 13, afbeelding 1 van 1
    • Flip the motherboard over so that the green side is facing you.
    • Use a soldering iron to desolder the two points to disconnect the open button.
    • For more information on soldering, please read the Hoe moet je (de-)solderen? guide.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 1,402
