Ga door naar hoofdinhoud
Samsung ATIV Smart PC 500T Front-Facing Camera Replacement
Wat je nodig hebt
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: stap 1, afbeelding 1 van 2 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: stap 1, afbeelding 2 van 2
      • Remove the stylus from the device.
      • Place the device screen-up on a hard surface, like a table.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 2, afbeelding 1 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 2, afbeelding 2 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 2, afbeelding 3 van 3
      • Insert a plastic pry tool or opening pick between the glass and plastic case.
      • Work your way around the plastic edge, unclipping the backplate.
      • Once the clips are loosened, remove the backplate. Some force may be necessary.
      • Though you may need to use force, be careful of the pry tool slipping and hurting you!
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: stap 3, afbeelding 3 van 3
      • Disconnect the three ribbon cables from the motherboard to free the battery.
      • Use your finger to lift the flap securing each ZIF connector.
      • Slide the ribbon cable out and towards you. Now it should be completely detached.
      • Repeat with the other two cables.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 4, afbeelding 1 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 4, afbeelding 2 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 4, afbeelding 3 van 3
      • Get a firm hold of the power cable as close to the clip as you can.
      • Pull the power cable up and out of the clip.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 5, afbeelding 1 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 5, afbeelding 2 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: stap 5, afbeelding 3 van 3
      • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
      • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 1 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 2 van 3 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: stap 6, afbeelding 3 van 3
      • Gently lift the front-facing camera with your forefinger.
      • Grip the camera with your thumb and forefinger and lift up to remove the camera from the socket at its base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Crystal Dinh
1.062 Reputatie
4 handleidingen geschreven
Baylor, Team 6-6, Williams Fall 2015 Lid van Baylor, Team 6-6, Williams Fall 2015
BU-WILLIAMS-F15S6G6
3 Leden
35 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 49
Altijd: 2,064
