Ga door naar hoofdinhoud
Samsung ATIV Book 4 Mouse Pad Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: stap 1, afbeelding 1 van 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: stap 1, afbeelding 2 van 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: stap 1, afbeelding 3 van 3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: stap 3, afbeelding 1 van 2 Samsung ATIV Book 4 Mouse Pad Replacement: stap 3, afbeelding 2 van 2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: stap 4, afbeelding 1 van 2 Samsung ATIV Book 4 Mouse Pad Replacement: stap 4, afbeelding 2 van 2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Conclusie
Daniel
342 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-7, Lauer Spring 2015 Lid van Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,119
