Ga door naar hoofdinhoud
Samsung ATIV Book 4 Battery Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 4 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung ATIV Book 4 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the computer upside down.
    • Remove 2 rubber pads, by prying up on them.
    • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
    • Remove the seven 6.5mm screws on exterior of computer.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung ATIV Book 4 Battery Replacement: stap 2, afbeelding 1 van 2 Samsung ATIV Book 4 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the panel by sliding it down and lifting it away from the computer.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung ATIV Book 4 Battery Replacement: stap 3, afbeelding 1 van 2 Samsung ATIV Book 4 Battery Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer, once all tabs are broken free.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung ATIV Book 4 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 3.5mm screws holding the battery.
    • Peel back the tape securing the wires to the battery.
    • Lift and remove the battery from its location.
    • Don't pull/tear the wires connected to battery harness.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung ATIV Book 4 Battery Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery harness from computer.
    • Completely remove the battery and replace it.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung ATIV Book 4 Battery Replacement: stap 6, afbeelding 1 van 1
    • Plug battery harness back in.
    • Assure the wires are pointed up (towards you) then plugging back in, as shown.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Chad
443 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-7, Lauer Spring 2015 Lid van Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 53
Altijd: 10,620
