Turn off the machine at the power switch on the back.
With your left hand, press and hold the top left and bottom right buttons at the same time. On this model, it is the espresso and menu buttons.
Turn the power switch on the back back on with your other hand. Release the buttons and the machine is in test mode
The next screen is split again. On the left is the temperature of the heater, if you press the top left button, the heater will turn on and the temperature will increase. On the right you can check the grinder by pressing the top right button, key figures for the motor are displayed.
The next key press takes you back to the beginning. To exit test mode, turn the device off and on again using the power switch on the back.
Work the steps in reverse order to reassemble your device.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
2 opmerkingen
Bin sehr dankbar fΓΌr diese Anleitung ππππ
meine Philips HD8829 hat leider kein Display ...
