Ga door naar hoofdinhoud
SG 552-1 Commando Spring Replacement
Wat je nodig hebt
    1. SG 552-1 Commando Spring Replacement, Gearbox: stap 1, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement, Gearbox: stap 1, afbeelding 2 van 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      Vraag FixBot
      Voeg opmerking toe
    2. SG 552-1 Commando Spring Replacement: stap 2, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 2, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      Vraag FixBot
      Voeg opmerking toe
    3. SG 552-1 Commando Spring Replacement: stap 3, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 3, afbeelding 2 van 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      Vraag FixBot
      Voeg opmerking toe
    4. SG 552-1 Commando Spring Replacement: stap 4, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 4, afbeelding 2 van 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Vraag FixBot
      Voeg opmerking toe
    5. SG 552-1 Commando Spring Replacement: stap 5, afbeelding 1 van 3 SG 552-1 Commando Spring Replacement: stap 5, afbeelding 2 van 3 SG 552-1 Commando Spring Replacement: stap 5, afbeelding 3 van 3
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      Vraag FixBot
      Voeg opmerking toe
    6. SG 552-1 Commando Spring Replacement: stap 6, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 6, afbeelding 2 van 2
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      Vraag FixBot
      Voeg opmerking toe
    7. SG 552-1 Commando Spring Replacement: stap 7, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 7, afbeelding 2 van 2
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      Vraag FixBot
      Voeg opmerking toe
    8. SG 552-1 Commando Spring Replacement: stap 8, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 8, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      Vraag FixBot
      Voeg opmerking toe
    9. SG 552-1 Commando Spring Replacement: stap 9, afbeelding 1 van 3 SG 552-1 Commando Spring Replacement: stap 9, afbeelding 2 van 3 SG 552-1 Commando Spring Replacement: stap 9, afbeelding 3 van 3
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      Vraag FixBot
      Voeg opmerking toe
    10. SG 552-1 Commando Spring Replacement: stap 10, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 10, afbeelding 2 van 2
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      Vraag FixBot
      Voeg opmerking toe
    11. SG 552-1 Commando Spring Replacement: stap 11, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 11, afbeelding 2 van 2
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      Vraag FixBot
      Voeg opmerking toe
    12. SG 552-1 Commando Spring Replacement: stap 12, afbeelding 1 van 3 SG 552-1 Commando Spring Replacement: stap 12, afbeelding 2 van 3 SG 552-1 Commando Spring Replacement: stap 12, afbeelding 3 van 3
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      Vraag FixBot
      Voeg opmerking toe
    1. SG 552-1 Commando Spring Replacement, Spring: stap 13, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement, Spring: stap 13, afbeelding 2 van 2
      • Remove these four 15mm screws.
      • Remove this single 8mm screw.
      • Using a Phillips #0 screwdriver, remove the following screws:
      • Remove this single 3mm screw.
      • Remove this single 14mm screw.
      • Detach the pieces unscrewed from the gearbox.
      Vraag FixBot
      Voeg opmerking toe
    2. SG 552-1 Commando Spring Replacement: stap 14, afbeelding 1 van 2 SG 552-1 Commando Spring Replacement: stap 14, afbeelding 2 van 2
      • Remove the piece covering the trigger.
      • Remove the safety piece.
      • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
      Vraag FixBot
      Voeg opmerking toe
    3. SG 552-1 Commando Spring Replacement: stap 15, afbeelding 1 van 1
      • Remove the metal piece.
      • Removing this piece will permanently damage the metal piece.
      Vraag FixBot
      Voeg opmerking toe
    4. SG 552-1 Commando Spring Replacement: stap 16, afbeelding 1 van 3 SG 552-1 Commando Spring Replacement: stap 16, afbeelding 2 van 3 SG 552-1 Commando Spring Replacement: stap 16, afbeelding 3 van 3
      • Remove the cover and pull out the spring.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Anika Morris
1 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-41, Regan Fall 2012 Lid van Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Leden
6 handleidingen geschreven
1Gids Commentaar
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 35
Altijd: 2,357
