Ga door naar hoofdinhoud
SG 552-1 Commando Barrel Replacement
Wat je nodig hebt
    1. SG 552-1 Commando Barrel Replacement, Barrel: stap 1, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement, Barrel: stap 1, afbeelding 2 van 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Pull the hand guard off.
      Vraag FixBot
      Voeg opmerking toe
    2. SG 552-1 Commando Barrel Replacement: stap 2, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 2, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
      Vraag FixBot
      Voeg opmerking toe
    3. SG 552-1 Commando Barrel Replacement: stap 3, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 3, afbeelding 2 van 2
      • Locate the button to fold over the folding stock and fold over the folding stock.
      • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
      Vraag FixBot
      Voeg opmerking toe
    4. SG 552-1 Commando Barrel Replacement: stap 4, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 4, afbeelding 2 van 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw located directly underneath the cocking lever.
      • Remove the 8mm screw beside the one you just removed.
      Vraag FixBot
      Voeg opmerking toe
    5. SG 552-1 Commando Barrel Replacement: stap 5, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 5, afbeelding 2 van 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Vraag FixBot
      Voeg opmerking toe
    6. SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 1 van 3 SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 2 van 3 SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 3 van 3
      • Pull the barrel out from the cover.
      • Remove the pieces at the end of the barrel.
      Vraag FixBot
      Voeg opmerking toe
    7. SG 552-1 Commando Barrel Replacement: stap 7, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 7, afbeelding 2 van 2
      • Remove the remaining pieces of on the ends of the barrel.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Laura Schulz
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-41, Regan Fall 2012 Lid van Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 2,054
