Ga door naar hoofdinhoud
SEGA Genesis Flashback Controller Buttons Replacement
Wat je nodig hebt
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 1 van 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 2 van 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 3 van 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: stap 2, afbeelding 1 van 2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: stap 2, afbeelding 2 van 2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
  3. SEGA Genesis Flashback Controller Buttons Replacement: stap 3, afbeelding 1 van 1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
  4. SEGA Genesis Flashback Controller Buttons Replacement: stap 4, afbeelding 1 van 1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
Conclusie
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Viet Nguyen
220 Reputatie
2 handleidingen geschreven
Cal Poly, Team S24-G12, Maness Spring 2018 Lid van Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 1,834
