Ga door naar hoofdinhoud
SEGA Genesis Flashback Back Cover Replacement
Wat je nodig hebt
  1. SEGA Genesis Flashback Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
    • Remove this screw with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. SEGA Genesis Flashback Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. SEGA Genesis Flashback Back Cover Replacement: stap 3, afbeelding 1 van 2 SEGA Genesis Flashback Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Use your fingers to peel off the four corner rubber feet on the bottom.
    • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
    Vraag FixBot
    Voeg opmerking toe
  4. SEGA Genesis Flashback Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Flip the case to its upright position.
    • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
    • Remove the back cover from the device.
    • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Viet Nguyen
220 Reputatie
2 handleidingen geschreven
Cal Poly, Team S24-G12, Maness Spring 2018 Lid van Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 1,073
