Inleiding
Use this guide to replace the trigger assembly in your Ryobi P235 Impact driver if power isn’t getting to the motor while using a fully charged battery.
The trigger assembly is what regulates how much power gets to the motor and what direction the motor spins.
When you reach step 7 and 8, the wires are soldered to the motor so a soldering iron will need to be used to disconnect them from the old trigger assembly and then reattach them to the new one.
Wat je nodig hebt
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
To reassemble your device, follow these instructions in reverse order starting at step 6.
3 andere personen hebben deze handleiding voltooid.
