Ga door naar hoofdinhoud
Ryobi CSB135L Power Cord Replacement
Wat je nodig hebt
  1. Ryobi CSB135L Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Place the saw on a flat surface.
    • Make sure the saw is unplugged and unpowered.
  2. Ryobi CSB135L Power Cord Replacement: stap 2, afbeelding 1 van 2 Ryobi CSB135L Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
    • Remove the front facing half of the handle assembly exposing the internals of the saw.
  3. Ryobi CSB135L Power Cord Replacement: stap 3, afbeelding 1 van 2 Ryobi CSB135L Power Cord Replacement: stap 3, afbeelding 2 van 2
    • After removing the handle assembly locate the trigger switch and wire nut in the saw.
    • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
    • Loosen the wire nut and remove the neutral wire from the power cord.
  4. Ryobi CSB135L Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Remove the power cord from the saw.
    • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
    • Wire strippers may be needed when installing the new power cord to expose the copper wire.
Conclusie
Nathanael Winchell
689 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 168
