Ga door naar hoofdinhoud
Royal Heat RS-100 Fan Replacement
Wat je nodig hebt
    1. Royal Heat RS-100 Fan Replacement, Panel: stap 1, afbeelding 1 van 1
      • Unplug the power cord.
      • Flip the device over so the bottom is facing up.
      • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Royal Heat RS-100 Fan Replacement: stap 2, afbeelding 1 van 3 Royal Heat RS-100 Fan Replacement: stap 2, afbeelding 2 van 3 Royal Heat RS-100 Fan Replacement: stap 2, afbeelding 3 van 3
      • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
      • Remove the front panel by pulling them apart. The front panel should come out easily.
      Vraag FixBot
      Voeg opmerking toe
    3. Royal Heat RS-100 Fan Replacement: stap 3, afbeelding 1 van 1
      • Remove the two dial caps from the two switches by lifting them up.
      Vraag FixBot
      Voeg opmerking toe
    1. Royal Heat RS-100 Fan Replacement, Fan: stap 4, afbeelding 1 van 1
      • Remove the three 10 mm screws that attach the fan to the heating coil assembly using the #2 Phillip Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Royal Heat RS-100 Fan Replacement: stap 5, afbeelding 1 van 1
      • Remove the 10 mm screw that attaches the fan to the heating coil assembly using the #2 Phillip Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Royal Heat RS-100 Fan Replacement: stap 6, afbeelding 1 van 1
      • Lift the heating coil assembly from the fan.
      Vraag FixBot
      Voeg opmerking toe
    4. Royal Heat RS-100 Fan Replacement: stap 7, afbeelding 1 van 1
      • Unplug the two blue wires that connect the fan to the Power/Fan Switch Circuit Board Assembly by pulling them away them from the fan.
      Vraag FixBot
      Voeg opmerking toe
    5. Royal Heat RS-100 Fan Replacement: stap 8, afbeelding 1 van 1
      • Flip the device over so the back panel is facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    6. Royal Heat RS-100 Fan Replacement: stap 9, afbeelding 1 van 1
      • Gently pry the back screen off of the device using a flathead screwdriver and remove it.
      Vraag FixBot
      Voeg opmerking toe
    7. Royal Heat RS-100 Fan Replacement: stap 10, afbeelding 1 van 1
      • Remove the four 10mm screws that attach the fan to the heater case using the #2 Phillip Screwdriver.
      • Lift the back plate from the fan by pulling it away from the fan.
      • Take note the direction of the fan blades. Putting the the fan in the wrong way will result in the air flow to come out the back of the device instead of the front.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Danyele Rampone
125 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-35, Amido Fall 2013 Lid van Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 Leden
63 handleidingen geschreven
1Gids Commentaar
QUESTION OFF TOPIC>>> sorry but don't know who else to ask..
Anyone know if Royal Heat is still in business maybe under a different name? I cannot find anything on the market today that compares to this little heater/fan. Was given one by elderly relative who said he has used it for 20 years and STILL works wonderfully. Poor fellow confined to a nursing home now and said he doesn't need it.
Thank You
Michael Gray - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 1,136
