Ga door naar hoofdinhoud
Roomba 650 wheel module Disassembly
Wat je nodig hebt
    1. Roomba 650 wheel module Disassembly, Removing the Side Brush: stap 1, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Removing the Side Brush: stap 1, afbeelding 2 van 2
      • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
      • Set the screw aside and pull the brush out.
      Vraag FixBot
      Voeg opmerking toe
    2. Roomba 650 wheel module Disassembly, Bottom Panel Removal: stap 2, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Bottom Panel Removal: stap 2, afbeelding 2 van 2
      • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
      • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
      • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
      Vraag FixBot
      Voeg opmerking toe
    1. Roomba 650 wheel module Disassembly, Main Wheels: stap 3, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Main Wheels: stap 3, afbeelding 2 van 2
      • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
      • The screws do not come all the way out.
      • Remove the wheels by pulling them out.
      Vraag FixBot
      Voeg opmerking toe
    1. Roomba 650 wheel module Disassembly, Spring: stap 4, afbeelding 1 van 1
      • Remove the shock spring to keep the wheel from jumping off when you remove the bolts
      Vraag FixBot
      Voeg opmerking toe
    2. Roomba 650 wheel module Disassembly, Suspension: stap 5, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Suspension: stap 5, afbeelding 2 van 2
      • Push the pin that acts as the pivot point for the suspension. I got away with just pushing with a screwdriver
      • Use pliers to pull from the other end to remove the pin completely
      • Unscrew all the remaining bolts
      Vraag FixBot
      Voeg opmerking toe
    3. Roomba 650 wheel module Disassembly, Take the gear housing apart: stap 6, afbeelding 1 van 3 Roomba 650 wheel module Disassembly, Take the gear housing apart: stap 6, afbeelding 2 van 3 Roomba 650 wheel module Disassembly, Take the gear housing apart: stap 6, afbeelding 3 van 3
      • Unscrew the housing bolts
      • Unscrew the two bolts that keep the motor in place
      • Remove the plastic stopper that keeps the motor wires in place
      • You should be able to take the motor out now
      Vraag FixBot
      Voeg opmerking toe
    4. Roomba 650 wheel module Disassembly, Inside the gear mechanism: stap 7, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Inside the gear mechanism: stap 7, afbeelding 2 van 2
      • With the motor out of the equation, try to move the wheel. If it's still stuck, than the problem is most likely the fibre buildup inside the wheel housing - as expected
      • All the gears should slide right off. Except the last one - the one that actually drives the wheel.
      Vraag FixBot
      Voeg opmerking toe
    5. Roomba 650 wheel module Disassembly, Remove the main gear: stap 8, afbeelding 1 van 1
      • Remove the main gear using a flathead screwdriver. This is the most difficult step - unfortunately the part was definitely not designed to be serviceable.
      • This will require a decent amount of force and even though the gears seem to be made out of nylon there's a chance this one could break
      Vraag FixBot
      Voeg opmerking toe
    6. Roomba 650 wheel module Disassembly, Remove wheel: stap 9, afbeelding 1 van 1
      • With the main gear out of the way the wheel should slide right off. In my case I had to wiggle it around a bit due to the fibre buildup
      • It is NOT recommended to rotate the wheel while trying to remove it. The rotation will enlarge the hole of the carrier and make the wheel loose.
      Vraag FixBot
      Voeg opmerking toe
    7. Roomba 650 wheel module Disassembly, Clean and reassemble: stap 10, afbeelding 1 van 2 Roomba 650 wheel module Disassembly, Clean and reassemble: stap 10, afbeelding 2 van 2
      • Remove all the gross hair buildup from the axle. Should come right off.
      Vraag FixBot
      Voeg opmerking toe
    8. Roomba 650 wheel module Disassembly, Done: stap 11, afbeelding 1 van 1
      • Much better! As you can see the only thing that keeps the wheel in place is the main gear. there is no problem of the gear slipping because the axle is splined. If you want you can use some threadlock to help securing the gear.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
31 andere personen hebben deze handleiding voltooid.
Nuno Covas
973 Reputatie
1 Handleiding geschreven
19Gids Commentaar
I could not get the hinge pin to slide out at all on the 650, so I just disassembled the plastic bits around the wheel enough to get at all the screws on the gear housing.
If you are wondering if this will solve your problem: I confirmed that this was causing a problem because I saw that the metal axle at the center of the wheel was recessed back from being flush the surface of the wheel “hub”. The hair and plastic tag strings had slowly forced the wheel off that shaft so it was rubbing against the side of it’s space and wouldn’t turn properly.
Tim Bendt - Antwoord Deel
Same here. The hair had slowly pushed the pin out and the wheel was rubbing and getting stuck.
laurent - Antwoord Deel
Same here also. Easy enough fix!
Akash Ramsaroop - Antwoord Deel
Do you know where to fond replacement gears? Th
Cody - Antwoord Deel
This guide 100% pass for Roomba 681.
Thank you!
p.s.
step 9 was more difficult than 8!
swenstyle - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 231
Altijd: 36,740
