Ga door naar hoofdinhoud
Roku XD 2050X Remote Battery Terminal Replacement
Wat je nodig hebt
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: stap 1, afbeelding 1 van 2 Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: stap 1, afbeelding 2 van 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: stap 2, afbeelding 1 van 2 Roku XD 2050X Remote Battery Terminal Replacement: stap 2, afbeelding 2 van 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: stap 3, afbeelding 1 van 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: stap 4, afbeelding 1 van 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: stap 5, afbeelding 1 van 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: stap 6, afbeelding 1 van 1
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
Conclusie
William
1.603 Reputatie
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 1,243
