Ga door naar hoofdinhoud
Roku 4 Remote Control Motherboard Replacement
Wat je nodig hebt
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: stap 1, afbeelding 1 van 1
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
    Vraag FixBot
    Voeg opmerking toe
  2. Roku 4 Remote Control Motherboard Replacement: stap 2, afbeelding 1 van 2 Roku 4 Remote Control Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
    Vraag FixBot
    Voeg opmerking toe
  3. Roku 4 Remote Control Motherboard Replacement: stap 3, afbeelding 1 van 2 Roku 4 Remote Control Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the batteries from the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  4. Roku 4 Remote Control Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
    Vraag FixBot
    Voeg opmerking toe
  5. Roku 4 Remote Control Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
    Vraag FixBot
    Voeg opmerking toe
  6. Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 1 van 3 Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 2 van 3 Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Hank Harrison
476 Reputatie
3 handleidingen geschreven
Baylor, Team S5-G4, Williams Spring 2017 Lid van Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 2,104
