Ga door naar hoofdinhoud
Roku 4 Ethernet Port Replacement
Wat je nodig hebt
  1. Roku 4 Ethernet Port Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Ethernet Port Replacement: stap 2, afbeelding 1 van 1
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Ethernet Port Replacement: stap 3, afbeelding 1 van 1
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Ethernet Port Replacement: stap 4, afbeelding 1 van 2 Roku 4 Ethernet Port Replacement: stap 4, afbeelding 2 van 2
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Ethernet Port Replacement: stap 5, afbeelding 1 van 2 Roku 4 Ethernet Port Replacement: stap 5, afbeelding 2 van 2
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Ethernet Port Replacement: stap 6, afbeelding 1 van 1
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Ethernet Port Replacement: stap 7, afbeelding 1 van 3 Roku 4 Ethernet Port Replacement: stap 7, afbeelding 2 van 3 Roku 4 Ethernet Port Replacement: stap 7, afbeelding 3 van 3
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Ethernet Port Replacement: stap 8, afbeelding 1 van 3 Roku 4 Ethernet Port Replacement: stap 8, afbeelding 2 van 3 Roku 4 Ethernet Port Replacement: stap 8, afbeelding 3 van 3
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Ethernet Port Replacement: stap 9, afbeelding 1 van 3 Roku 4 Ethernet Port Replacement: stap 9, afbeelding 2 van 3 Roku 4 Ethernet Port Replacement: stap 9, afbeelding 3 van 3
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
  10. Roku 4 Ethernet Port Replacement, Ethernet Port: stap 10, afbeelding 1 van 1
    • Lay the motherboard facedown on the table so you can see the large black ethernet port with several gold connections below it.
    • Use a soldering iron to desolder each of the ethernet port's connections to the motherboard.
    • Consult iFixit's Soldering Skills guide to learn how to safely use the soldering iron.
  11. Roku 4 Ethernet Port Replacement: stap 11, afbeelding 1 van 1
    • Using your thumb and pointer finger, carefully pinch the Ethernet port and pull it to the right, away from the motherboard, to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hank Harrison
449 Reputatie
3 handleidingen geschreven
Baylor, Team S5-G4, Williams Spring 2017 Lid van Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Leden
4 handleidingen geschreven
3 opmerkingen
Is that the HDMI port
cruzanbay45 - Antwoord
Is that the HDMI port on roku
where do you get the HDMI port for roku
mar plane - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,158
