Ga door naar hoofdinhoud
Roku 3 Remote Control Buttons Replacement
Wat je nodig hebt
  1. Roku 3 Remote Control Buttons Replacement, Remote Control Battery: stap 1, afbeelding 1 van 1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
    Vraag FixBot
    Voeg opmerking toe
  2. Roku 3 Remote Control Buttons Replacement: stap 2, afbeelding 1 van 2 Roku 3 Remote Control Buttons Replacement: stap 2, afbeelding 2 van 2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Roku 3 Remote Control Buttons Replacement: stap 3, afbeelding 1 van 1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
    Vraag FixBot
    Voeg opmerking toe
  4. Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: stap 4, afbeelding 1 van 2 Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: stap 4, afbeelding 2 van 2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  5. Roku 3 Remote Control Buttons Replacement: stap 5, afbeelding 1 van 2 Roku 3 Remote Control Buttons Replacement: stap 5, afbeelding 2 van 2
    • Gently pry open the remote using the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  6. Roku 3 Remote Control Buttons Replacement: stap 6, afbeelding 1 van 2 Roku 3 Remote Control Buttons Replacement: stap 6, afbeelding 2 van 2
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    Vraag FixBot
    Voeg opmerking toe
  7. Roku 3 Remote Control Buttons Replacement: stap 7, afbeelding 1 van 1
    • Carefully flip over the front casing side of the remote so that the buttons drop onto the table.
    • If the buttons do not drop immediately, use your fingers to peal them off the front casing of the remote.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Isobelle Espiritu
591 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-2, Livingston Fall 2016 Lid van Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Leden
6 handleidingen geschreven
4Gids Commentaar
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Patrick Canady - Antwoord Deel
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
J Thomson - Antwoord Deel
Where can I find a component layout?
Rey De Castro - Antwoord Deel
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
setuproku code - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 6,487
