Ga door naar hoofdinhoud
Roku 2 Remote Control Buttons Replacement
Wat je nodig hebt
    1. Roku 2 Remote Control Buttons Replacement, Remote Battery: stap 1, afbeelding 1 van 1
      • Turn over remote and press down on tab to remove.
      Vraag FixBot
      Voeg opmerking toe
    2. Roku 2 Remote Control Buttons Replacement: stap 2, afbeelding 1 van 1
      • Remove batteries
      Vraag FixBot
      Voeg opmerking toe
    3. Roku 2 Remote Control Buttons Replacement: stap 3, afbeelding 1 van 1
      • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
      • Insert Roku tab back on to its slot.
      Vraag FixBot
      Voeg opmerking toe
    1. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: stap 4, afbeelding 1 van 1
      • After removing the batteries, use a #000 Phillips to remove the screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Roku 2 Remote Control Buttons Replacement, Pry the remote open: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to pry open the remote.
      Vraag FixBot
      Voeg opmerking toe
    3. Roku 2 Remote Control Buttons Replacement: stap 6, afbeelding 1 van 1
      • Continue along the top of the remote to lift it off the remote.
      • Lift the top of the remote off very carefully so that board doesn't fall.
      Vraag FixBot
      Voeg opmerking toe
    4. Roku 2 Remote Control Buttons Replacement, Replace the buttons: stap 7, afbeelding 1 van 1
      • Identify the buttons to be replaced and take them out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Alex Saltos
526 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-5, Sullivan Fall 2015 Lid van USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Leden
12 handleidingen geschreven
9Gids Commentaar
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - Antwoord Deel
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - Antwoord Deel
And where exactly do you buy the new buttons ??
bonzo dog - Antwoord Deel
And just where exactly do you buy the new buttons??
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 135
Altijd: 56,715
