Ga door naar hoofdinhoud
Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement
Wat je nodig hebt
  1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: stap 1, afbeelding 1 van 1
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
    Vraag FixBot
    Voeg opmerking toe
  2. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 3, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 3, afbeelding 2 van 2
    • Flip the device over and remove the top casing from the sender.
    Vraag FixBot
    Voeg opmerking toe
  4. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, Sender Wireless Audio Module Chip: stap 4, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
    Vraag FixBot
    Voeg opmerking toe
  5. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 7, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 7, afbeelding 2 van 2
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
    Vraag FixBot
    Voeg opmerking toe
  8. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 8, afbeelding 1 van 1
    • Flip over the motherboard and wireless audio module chip.
    Vraag FixBot
    Voeg opmerking toe
  9. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
    Vraag FixBot
    Voeg opmerking toe
  10. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: stap 10, afbeelding 1 van 1
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To install the new wireless module chip, follow these instructions in reverse order.
Once the sender has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new wireless module chip has been properly assembled.
Caitlin Charlton
756 Reputatie
6 handleidingen geschreven
Baylor, Team 4-2, Williams Spring 2015 Lid van Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Leden
12 handleidingen geschreven
3Gids Commentaar
Does Rocketfish offer a replacement board?
Bob David - Antwoord Deel
“No Parts Required” is a joke . Where are the replacement boards available from?
Petie Martin - Antwoord Deel
I used the wrong ac adapter, which worked for a few weeks then the unit died and won't power on. Would anyone know what I should check out with the multi meter to see what's wrong and see if I can fix it? Thanks!
Adam Sawicki - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 41
Altijd: 1,917
