Ga door naar hoofdinhoud
Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement
Wat je nodig hebt
  1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: stap 1, afbeelding 1 van 1
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
  2. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
  3. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 3, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 3, afbeelding 2 van 2
    • Flip the device over and remove the top casing from the sender.
  4. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Wireless Audio Module Chip: stap 4, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
  5. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
  6. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
  7. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 7, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 7, afbeelding 2 van 2
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
  8. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 8, afbeelding 1 van 1
    • Flip over the motherboard and wireless audio module chip.
  9. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 9, afbeelding 1 van 1
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
  10. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: stap 10, afbeelding 1 van 1
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
  11. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: stap 11, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: stap 11, afbeelding 2 van 2
    • Desolder the four metallic clasps that attach the panel to the motherboard.
    • For soldering techniques, follow the step in iFixit's soldering guide.
    • Do not attempt to solder if you are inexperienced.
Conclusie
To attach a new speaker input terminal, follow these instructions in reverse order.
Caitlin Charlton
756 Reputatie
6 handleidingen geschreven
Baylor, Team 4-2, Williams Spring 2015 Lid van Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Leden
Één opmerking
Where can I get a replacement input terminal?
Greg Surrett (terminal case) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 2,262
