Ga door naar hoofdinhoud
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Wat je nodig hebt
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: stap 1, afbeelding 1 van 1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    Vraag FixBot
    Voeg opmerking toe
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    Vraag FixBot
    Voeg opmerking toe
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 3, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 3, afbeelding 2 van 2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    Vraag FixBot
    Voeg opmerking toe
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: stap 4, afbeelding 1 van 1
    • Unscrew the 10 mm screw holding the wireless audio module.
    Vraag FixBot
    Voeg opmerking toe
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 5, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
    Vraag FixBot
    Voeg opmerking toe
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: stap 6, afbeelding 1 van 1
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To install the new wireless audio module chip, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Caitlin Charlton
756 Reputatie
6 handleidingen geschreven
Baylor, Team 4-2, Williams Spring 2015 Lid van Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Leden
12 handleidingen geschreven
1Gids Commentaar
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 2,548
