Ga door naar hoofdinhoud
Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
Wat je nodig hebt
  1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: stap 1, afbeelding 1 van 1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    Vraag FixBot
    Voeg opmerking toe
  2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    Vraag FixBot
    Voeg opmerking toe
  3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: stap 3, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: stap 3, afbeelding 2 van 2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    Vraag FixBot
    Voeg opmerking toe
  4. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: stap 4, afbeelding 1 van 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: stap 4, afbeelding 2 van 2
    • One 10 mm screw is securing the LED 14.14 chip.
    • Unscrew the chip.
    • Use a Phillips #1 Screwdriver for this step.
    Vraag FixBot
    Voeg opmerking toe
  5. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, gently pull the LED plug out of the mother board.
    Vraag FixBot
    Voeg opmerking toe
  6. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently feed the LED wire under the power supply to completely remove it from the sender.
    • Remove the faulty LED 14.14 chip from the receiver.
    • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
Caitlin Charlton
756 Reputatie
6 handleidingen geschreven
Baylor, Team 4-2, Williams Spring 2015 Lid van Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Leden
12 handleidingen geschreven
2Gids Commentaar
Where do I get the chip???
sean moore - Antwoord Deel
where do I get chip?
bugsyc26 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 2,491
