Ga door naar hoofdinhoud
Ring Video Battery and Wi-Fi Antenna Replacement.
  1. Ring Video Battery and Wi-Fi Antenna Replacement., Battery and Wi-Fi antenna: stap 1, afbeelding 1 van 1
    • Battery made of 2 units and a controller card with a 5-wire output. This battery can possibly be replaced by another one of the same final voltage, either by a parallel arrangement or by a direct connection of a unit.
    • The final amperage doesn´t need to be the same as the original battery.
    • The shape of the new battery doesn´t need to be the same either, since it can be placed externally just by inserting the cables.
  2. Ring Video Battery and Wi-Fi Antenna Replacement.: stap 2, afbeelding 1 van 1
    • Both options, using the controller card to facilitate the connection to the main motherboard, so it can recognize the power source.
  3. Ring Video Battery and Wi-Fi Antenna Replacement.: stap 3, afbeelding 1 van 1
    • The main motherboard with antenna card, and the chance of upgrading it with a generic antenna, improving reception and transmission.
Conclusie
To reassemble your device, follow these instructions in reverse order
Met dank aan deze vertalers:
es en
100%
Penny helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
AZUL BOCANDREA
97 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 1,441
