Ga door naar hoofdinhoud
Ring Stick Up Cam Microphone Replacement
Wat je nodig hebt
    1. Ring Stick Up Cam Microphone Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Ring Stick Up Cam Microphone Replacement: stap 2, afbeelding 1 van 1
      • Pry off the aluminum plate using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. Ring Stick Up Cam Microphone Replacement: stap 3, afbeelding 1 van 1
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      Vraag FixBot
      Voeg opmerking toe
    4. Ring Stick Up Cam Microphone Replacement: stap 4, afbeelding 1 van 1
      • Pry off the back cover using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. Ring Stick Up Cam Microphone Replacement: stap 5, afbeelding 1 van 1
      • Disconnect the battery power leads using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    6. Ring Stick Up Cam Microphone Replacement: stap 6, afbeelding 1 van 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Vraag FixBot
      Voeg opmerking toe
    1. Ring Stick Up Cam Microphone Replacement, Camera: stap 7, afbeelding 1 van 1
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Ring Stick Up Cam Microphone Replacement: stap 8, afbeelding 1 van 1
      • Disconnect the ribbon connector shown in the photo.
      Vraag FixBot
      Voeg opmerking toe
    3. Ring Stick Up Cam Microphone Replacement: stap 9, afbeelding 1 van 1
      • Remove the motherboard from the device by hand.
      Vraag FixBot
      Voeg opmerking toe
    4. Ring Stick Up Cam Microphone Replacement: stap 10, afbeelding 1 van 1
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Ring Stick Up Cam Microphone Replacement: stap 11, afbeelding 1 van 1
      • Remove the three plastic spacers shown in the photo by hand.
      Vraag FixBot
      Voeg opmerking toe
    6. Ring Stick Up Cam Microphone Replacement: stap 12, afbeelding 1 van 1
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Ring Stick Up Cam Microphone Replacement: stap 13, afbeelding 1 van 1
      • Lift the camera board out of the housing using your hand.
      Vraag FixBot
      Voeg opmerking toe
    1. Ring Stick Up Cam Microphone Replacement, Microphone: stap 14, afbeelding 1 van 1
      • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Ring Stick Up Cam Microphone Replacement: stap 15, afbeelding 1 van 1
      • Use a plastic opening tool to carefully pry the microphone from the housing.
      Vraag FixBot
      Voeg opmerking toe
    3. Ring Stick Up Cam Microphone Replacement: stap 16, afbeelding 1 van 1
      • Use your hands to remove the daughterboard containing the microphone from the housing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Chunyue Liu
273 Reputatie
2 handleidingen geschreven
UC Davis, Team S18-G3, Lore Winter 2019 Lid van UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 3,169
