Ga door naar hoofdinhoud
Ring Outdoor Security Cam Microphone Replacement
Wat je nodig hebt
    1. Ring Outdoor Security Cam Microphone Replacement, Microphone: stap 1, afbeelding 1 van 1
      • Remove the six 6 mm Phillips #00 screws from the back on the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Ring Outdoor Security Cam Microphone Replacement: stap 2, afbeelding 1 van 1
      • Pry off the aluminum plate using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. Ring Outdoor Security Cam Microphone Replacement: stap 3, afbeelding 1 van 1
      • Use an opening tool to pry the back plate off of the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Ring Outdoor Security Cam Microphone Replacement: stap 4, afbeelding 1 van 1
      • Disconnect the battery power leads using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. Ring Outdoor Security Cam Microphone Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Vraag FixBot
      Voeg opmerking toe
    6. Ring Outdoor Security Cam Microphone Replacement: stap 6, afbeelding 1 van 1
      • Disconnect the ribbon cable carefully at the bottom of the device.
      • Remove the 3 silver 6 mm Phillips #00 screws from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Ring Outdoor Security Cam Microphone Replacement: stap 7, afbeelding 1 van 1
      • Pull the top of the motherboard up and out of the device.
      Vraag FixBot
      Voeg opmerking toe
    8. Ring Outdoor Security Cam Microphone Replacement: stap 8, afbeelding 1 van 2 Ring Outdoor Security Cam Microphone Replacement: stap 8, afbeelding 2 van 2
      • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
      • Remove the 3 plastic spacers on the device.
      Vraag FixBot
      Voeg opmerking toe
    9. Ring Outdoor Security Cam Microphone Replacement: stap 9, afbeelding 1 van 3 Ring Outdoor Security Cam Microphone Replacement: stap 9, afbeelding 2 van 3 Ring Outdoor Security Cam Microphone Replacement: stap 9, afbeelding 3 van 3
      • Pry the motherboard out with a plastic opening tool
      • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
      Vraag FixBot
      Voeg opmerking toe
    10. Ring Outdoor Security Cam Microphone Replacement: stap 10, afbeelding 1 van 1
      • Remove the microphone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
WilliamB22
968 Reputatie
5 handleidingen geschreven
1Gids Commentaar
Where can i get the replacement?
Sam - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 802
