Ga door naar hoofdinhoud
Ring Outdoor Security Cam Infrared Sensor Replacement
Wat je nodig hebt
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: stap 1, afbeelding 1 van 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 2, afbeelding 1 van 1
    • Pry off the aluminum plate using a plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 3, afbeelding 1 van 1
    • Using the same tool pry the back plate off of the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery power leads using a plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    Vraag FixBot
    Voeg opmerking toe
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 7, afbeelding 1 van 1
    • Pull the top of the motherboard up and out of the device.
    Vraag FixBot
    Voeg opmerking toe
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 8, afbeelding 1 van 2 Ring Outdoor Security Cam Infrared Sensor Replacement: stap 8, afbeelding 2 van 2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
    Vraag FixBot
    Voeg opmerking toe
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 9, afbeelding 1 van 3 Ring Outdoor Security Cam Infrared Sensor Replacement: stap 9, afbeelding 2 van 3 Ring Outdoor Security Cam Infrared Sensor Replacement: stap 9, afbeelding 3 van 3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
    Vraag FixBot
    Voeg opmerking toe
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: stap 10, afbeelding 1 van 1
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
WilliamB22
968 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 584
