Ga door naar hoofdinhoud
Ridgid R82005 Trigger Switch Replacement
Wat je nodig hebt
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: stap 1, afbeelding 1 van 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: stap 2, afbeelding 1 van 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: stap 3, afbeelding 1 van 3 Ridgid R82005 Trigger Switch Replacement: stap 3, afbeelding 2 van 3 Ridgid R82005 Trigger Switch Replacement: stap 3, afbeelding 3 van 3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: stap 4, afbeelding 1 van 3 Ridgid R82005 Trigger Switch Replacement: stap 4, afbeelding 2 van 3 Ridgid R82005 Trigger Switch Replacement: stap 4, afbeelding 3 van 3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
Conclusie
Alex Cominos
376 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Spring 2019 Lid van USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 447
