Ga door naar hoofdinhoud
Ridgid R82005 Motor Replacement
Wat je nodig hebt
  1. Ridgid R82005  Motor Replacement, Housing Assembly: stap 1, afbeelding 1 van 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  Motor Replacement: stap 2, afbeelding 1 van 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  Motor Replacement: stap 3, afbeelding 1 van 2 Ridgid R82005  Motor Replacement: stap 3, afbeelding 2 van 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  Motor Replacement: stap 4, afbeelding 1 van 2 Ridgid R82005  Motor Replacement: stap 4, afbeelding 2 van 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  Motor Replacement, Motor: stap 5, afbeelding 1 van 3 Ridgid R82005  Motor Replacement, Motor: stap 5, afbeelding 2 van 3 Ridgid R82005  Motor Replacement, Motor: stap 5, afbeelding 3 van 3
    • Push the two pins through the motor assembly.
    • We used an Alan wrench to push the pins through, but any small tool will do.
    • Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
    • To learn how to solder, check out the How to Solder and Desolder Connections guide.
    • Make sure all drill components fit properly in the grooves of the Housing Assembly.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrew McPherson
479 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Spring 2019 Lid van USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 813
