Ga door naar hoofdinhoud
Ridgid GEN5X R8642 Switch Replacement
Wat je nodig hebt
  1. Ridgid GEN5X R8642 Switch Replacement, Switch: stap 1, afbeelding 1 van 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Switch Replacement: stap 3, afbeelding 1 van 2 Ridgid GEN5X R8642 Switch Replacement: stap 3, afbeelding 2 van 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Switch Replacement: stap 4, afbeelding 1 van 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Switch Replacement: stap 5, afbeelding 1 van 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Switch Replacement: stap 6, afbeelding 1 van 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
  7. Ridgid GEN5X R8642 Switch Replacement: stap 7, afbeelding 1 van 1
    • Remove the soldered connection from the switch assembly.
  8. Ridgid GEN5X R8642 Switch Replacement: stap 8, afbeelding 1 van 1
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 287
