Inleiding
This guide is to help users replace their faulty battery port for the Ridgid GEN5X R8642 saw. For this guide you will need: a soldering iron, a spudger, a T20 Torx Screwdriver, Battery Port for Ridgid GEN5X R8642, and a good attitude.
Wat je nodig hebt
Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
Remove the plastic wire covers to the red and black connections on the switch assembly.
Desolder the connections on both the red and black wire using a soldering iron.
Once the solder is removed, pull out the wires with the battery port attached to the wires.
