Ga door naar hoofdinhoud
Ridgid GEN5X R8642 Motor Replacement
Wat je nodig hebt
  1. Ridgid GEN5X R8642  Motor Replacement, Motor Replacement: stap 1, afbeelding 1 van 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642  Motor Replacement: stap 2, afbeelding 1 van 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642  Motor Replacement: stap 3, afbeelding 1 van 2 Ridgid GEN5X R8642  Motor Replacement: stap 3, afbeelding 2 van 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642  Motor Replacement: stap 4, afbeelding 1 van 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642  Motor Replacement: stap 5, afbeelding 1 van 2 Ridgid GEN5X R8642  Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642  Motor Replacement: stap 6, afbeelding 1 van 2 Ridgid GEN5X R8642  Motor Replacement: stap 6, afbeelding 2 van 2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642  Motor Replacement: stap 7, afbeelding 1 van 3 Ridgid GEN5X R8642  Motor Replacement: stap 7, afbeelding 2 van 3 Ridgid GEN5X R8642  Motor Replacement: stap 7, afbeelding 3 van 3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642  Motor Replacement: stap 8, afbeelding 1 van 2 Ridgid GEN5X R8642  Motor Replacement: stap 8, afbeelding 2 van 2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642  Motor Replacement: stap 9, afbeelding 1 van 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
  10. Ridgid GEN5X R8642  Motor Replacement: stap 10, afbeelding 1 van 1
    • Remove the soldered connection from the switch assembly.
  11. Ridgid GEN5X R8642  Motor Replacement: stap 11, afbeelding 1 van 2 Ridgid GEN5X R8642  Motor Replacement: stap 11, afbeelding 2 van 2
    • Solder both connections of the new motor replacement to the switch assembly.
Conclusie
To reassemble your device follow these instructions in reverse order.
Mauricio Moreno
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 428
