Ga door naar hoofdinhoud
Rexing V1P Plus Rear Camera Replacement
Wat je nodig hebt
  1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: stap 1, afbeelding 2 van 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: stap 1, afbeelding 3 van 3
    • Begin by orienting the rear camera lens facing up.
    • Twist the adhesive mount surface parallel to the camera lens.
    • Pull the mounting ring axially away from the camera case.
    Vraag FixBot
    Voeg opmerking toe
  2. Rexing V1P Plus Rear Camera Replacement: stap 2, afbeelding 1 van 3 Rexing V1P Plus Rear Camera Replacement: stap 2, afbeelding 2 van 3 Rexing V1P Plus Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • Locate the small indentation on the camera case previously covered by the mounting ring.
    • Insert a spudger in the case seam and twist it to lever open the camera case.
    • Use the spudger to pry the case the rest of the way open.
    • Remove the top casing from the rear camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Rexing V1P Plus Rear Camera Replacement: stap 3, afbeelding 1 van 2 Rexing V1P Plus Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the camera and camera motherboard from the casing.
    • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
    Vraag FixBot
    Voeg opmerking toe
  4. Rexing V1P Plus Rear Camera Replacement: stap 4, afbeelding 1 van 3 Rexing V1P Plus Rear Camera Replacement: stap 4, afbeelding 2 van 3 Rexing V1P Plus Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Rexing V1P Plus Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • With the screws removed, the rear camera can be separated from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 34
Altijd: 638
