Wat je nodig hebt
Place curling iron on a flat surface along with required tools and barrel shell replacement.
Gereedschap gebruikt in deze stap:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Unscrew the 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
Set the two screws and barrel clip aside for reassembly.
Bijna klaar!
Conclusie
