Ga door naar hoofdinhoud
Retroid Pocket Flip Motherboard Replacement
Wat je nodig hebt
  1. Retroid Pocket Flip Motherboard Replacement, Back Plate Assembly: stap 1, afbeelding 1 van 2 Retroid Pocket Flip Motherboard Replacement, Back Plate Assembly: stap 1, afbeelding 2 van 2
    • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
    • Use a plastic opening pick to carefully separate the back cover from the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Retroid Pocket Flip Motherboard Replacement: stap 2, afbeelding 1 van 2 Retroid Pocket Flip Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic spudger to carefully lift and disconnect the battery connector.
    • Use tweezers to disconnect the connector from its socket.
    Vraag FixBot
    Voeg opmerking toe
  3. Retroid Pocket Flip Motherboard Replacement, Joystick: stap 3, afbeelding 1 van 2 Retroid Pocket Flip Motherboard Replacement, Joystick: stap 3, afbeelding 2 van 2
    • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
    • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
    • Use tweezers to remove the "R" sticker to reveal the last screw.
    Vraag FixBot
    Voeg opmerking toe
  4. Retroid Pocket Flip Motherboard Replacement: stap 4, afbeelding 1 van 3 Retroid Pocket Flip Motherboard Replacement: stap 4, afbeelding 2 van 3 Retroid Pocket Flip Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
    • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
    • Use a plastic spudger to carefully separate the shield from the board.
    • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
    Vraag FixBot
    Voeg opmerking toe
  5. Retroid Pocket Flip Motherboard Replacement: stap 5, afbeelding 1 van 3 Retroid Pocket Flip Motherboard Replacement: stap 5, afbeelding 2 van 3 Retroid Pocket Flip Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
    • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
    Vraag FixBot
    Voeg opmerking toe
  6. Retroid Pocket Flip Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Retroid Pocket Flip Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Retroid Pocket Flip Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
    • Use tweezers to disconnect the ribbon cables from the board.
    • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
    • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Retroid Pocket Flip Motherboard Replacement: stap 7, afbeelding 1 van 2 Retroid Pocket Flip Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
    • Carefully lift the motherboard out of the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Eya Sarah AHMED
85 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 54
Altijd: 137
