Ga door naar hoofdinhoud
Retroid Pocket 3 Trigger Button Replacement
Wat je nodig hebt
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Vraag FixBot
    Voeg opmerking toe
  2. Retroid Pocket 3 Trigger Button Replacement: stap 2, afbeelding 1 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 2, afbeelding 2 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Retroid Pocket 3 Trigger Button Replacement: stap 3, afbeelding 1 van 2 Retroid Pocket 3 Trigger Button Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Retroid Pocket 3 Trigger Button Replacement: stap 4, afbeelding 1 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 4, afbeelding 2 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: stap 5, afbeelding 1 van 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: stap 5, afbeelding 2 van 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: stap 5, afbeelding 3 van 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    Vraag FixBot
    Voeg opmerking toe
  6. Retroid Pocket 3 Trigger Button Replacement: stap 6, afbeelding 1 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 6, afbeelding 2 van 3 Retroid Pocket 3 Trigger Button Replacement: stap 6, afbeelding 3 van 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 83
Altijd: 1,610
