Ga door naar hoofdinhoud
Retroid Pocket 3 Button Pad Replacement
Wat je nodig hebt
  1. Retroid Pocket 3 Button Pad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Vraag FixBot
    Voeg opmerking toe
  2. Retroid Pocket 3 Button Pad Replacement: stap 2, afbeelding 1 van 3 Retroid Pocket 3 Button Pad Replacement: stap 2, afbeelding 2 van 3 Retroid Pocket 3 Button Pad Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Retroid Pocket 3 Button Pad Replacement: stap 3, afbeelding 1 van 2 Retroid Pocket 3 Button Pad Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Retroid Pocket 3 Button Pad Replacement: stap 4, afbeelding 1 van 3 Retroid Pocket 3 Button Pad Replacement: stap 4, afbeelding 2 van 3 Retroid Pocket 3 Button Pad Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Retroid Pocket 3 Button Pad Replacement, Button Pad: stap 5, afbeelding 1 van 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: stap 5, afbeelding 2 van 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: stap 5, afbeelding 3 van 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    Vraag FixBot
    Voeg opmerking toe
  6. Retroid Pocket 3 Button Pad Replacement: stap 6, afbeelding 1 van 2 Retroid Pocket 3 Button Pad Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    • Carefully lift the board out of the device.
    Vraag FixBot
    Voeg opmerking toe
  7. Retroid Pocket 3 Button Pad Replacement: stap 7, afbeelding 1 van 2 Retroid Pocket 3 Button Pad Replacement: stap 7, afbeelding 2 van 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    Vraag FixBot
    Voeg opmerking toe
  8. Retroid Pocket 3 Button Pad Replacement: stap 8, afbeelding 1 van 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  9. Retroid Pocket 3 Button Pad Replacement: stap 9, afbeelding 1 van 3 Retroid Pocket 3 Button Pad Replacement: stap 9, afbeelding 2 van 3 Retroid Pocket 3 Button Pad Replacement: stap 9, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  10. Retroid Pocket 3 Button Pad Replacement: stap 10, afbeelding 1 van 3 Retroid Pocket 3 Button Pad Replacement: stap 10, afbeelding 2 van 3 Retroid Pocket 3 Button Pad Replacement: stap 10, afbeelding 3 van 3
    • Carefully pry up the silicone button pad with a Spudger tool.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 57
Altijd: 1,250
