Ga door naar hoofdinhoud
Retroid Pocket 3 Battery Replacement
Wat je nodig hebt
  1. Retroid Pocket 3 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Vraag FixBot
    Voeg opmerking toe
  2. Retroid Pocket 3 Battery Replacement: stap 2, afbeelding 1 van 3 Retroid Pocket 3 Battery Replacement: stap 2, afbeelding 2 van 3 Retroid Pocket 3 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Retroid Pocket 3 Battery Replacement: stap 3, afbeelding 1 van 2 Retroid Pocket 3 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Retroid Pocket 3 Battery Replacement: stap 4, afbeelding 1 van 3 Retroid Pocket 3 Battery Replacement: stap 4, afbeelding 2 van 3 Retroid Pocket 3 Battery Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
Hi, the battery of the Retroid Pocket 3 and 3Plus is customized for the manufacturing company, so it is not possible to find it in online stores and Retroid does not sell it as a spare part. Can you suggest a battery that has similar characteristics such as size, voltage and capacity? The battery is a 755565 3.8V and 4000mAh (for the Retroid 3 and 4500mAh for the 3Plus), can you suggest a 3.7V battery but with similar dimensions? Better a little smaller, otherwise it does not close inside the case. Thanks
Gianluca - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 190
Altijd: 4,792
