Ga door naar hoofdinhoud
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Wat je nodig hebt
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 3 van 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 3 van 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 3 van 3
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
Conclusie
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
320 Reputatie
3 handleidingen geschreven
USF Tampa, Team S4-G4, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 691
