Ga door naar hoofdinhoud
Resetting the Clock
    1. Resetting the Clock, Resetting the Clock: stap 1, afbeelding 1 van 1
      • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
      Vraag FixBot
      Voeg opmerking toe
    2. Resetting the Clock: stap 2, afbeelding 1 van 2 Resetting the Clock: stap 2, afbeelding 2 van 2
      • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
      Vraag FixBot
      Voeg opmerking toe
    3. Resetting the Clock: stap 3, afbeelding 1 van 1
      • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
      Vraag FixBot
      Voeg opmerking toe
    4. Resetting the Clock: stap 4, afbeelding 1 van 1
      • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
      Vraag FixBot
      Voeg opmerking toe
    5. Resetting the Clock: stap 5, afbeelding 1 van 1
      • Press the "VOLUME +" button to advance the minutes forward.
      Vraag FixBot
      Voeg opmerking toe
    6. Resetting the Clock: stap 6, afbeelding 1 van 1
      • Press the "VOLUME -" button to decrease the minutes.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-50, Forte Fall 2012 Lid van Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,829
