Ga door naar hoofdinhoud
ResMed S9 VPAP Auto Knob Replacement
Wat je nodig hebt
  1. ResMed S9 VPAP Auto Knob Replacement, Control Knob: stap 1, afbeelding 1 van 2 ResMed S9 VPAP Auto Knob Replacement, Control Knob: stap 1, afbeelding 2 van 2
    • Flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2mm Torx T3.
  2. ResMed S9 VPAP Auto Knob Replacement: stap 2, afbeelding 1 van 2 ResMed S9 VPAP Auto Knob Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to pry off the back panel.
  3. ResMed S9 VPAP Auto Knob Replacement: stap 3, afbeelding 1 van 2 ResMed S9 VPAP Auto Knob Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove the front panel to expose the internal components.
  4. ResMed S9 VPAP Auto Knob Replacement: stap 4, afbeelding 1 van 3 ResMed S9 VPAP Auto Knob Replacement: stap 4, afbeelding 2 van 3 ResMed S9 VPAP Auto Knob Replacement: stap 4, afbeelding 3 van 3
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
  5. ResMed S9 VPAP Auto Knob Replacement: stap 5, afbeelding 1 van 2 ResMed S9 VPAP Auto Knob Replacement: stap 5, afbeelding 2 van 2
    • Plug in and heat up the soldering iron.
  6. ResMed S9 VPAP Auto Knob Replacement: stap 6, afbeelding 1 van 3 ResMed S9 VPAP Auto Knob Replacement: stap 6, afbeelding 2 van 3 ResMed S9 VPAP Auto Knob Replacement: stap 6, afbeelding 3 van 3
    • Locate the knob pins.
    • Desolder the solder pins on each side of the knob.
    • For more details on soldering best practices, check out our Hoe moet je (de-)solderen? guide.
    • Be careful not to make contact with any of the other parts of the motherboard.
    • Remove the knob and replace it.
Conclusie
4 opmerkingen
Do you have a source for the auto knob or a part number?
scott jensen - Antwoord
Do you have a source for this knob/switch or a part number?
You need a new rotary encoder, however the very popular and cheap EC11 does not work properly, you need a ddm 427 encoder, which is not very easy to find.
NG G. -
I found the right encoder from digikey. It has the wrong type of knob stem, but it works. It is the DDM 427.
Jim Burianek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 692
