Ga door naar hoofdinhoud
Replacing an Atari Capacitor
Wat je nodig hebt
  1. Replacing an Atari Capacitor, Atari Lynx: stap 1, afbeelding 1 van 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing an Atari Capacitor: stap 2, afbeelding 1 van 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing an Atari Capacitor: stap 3, afbeelding 1 van 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing an Atari Capacitor: stap 4, afbeelding 1 van 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing an Atari Capacitor, C10 Capacitor: stap 5, afbeelding 1 van 2 Replacing an Atari Capacitor, C10 Capacitor: stap 5, afbeelding 2 van 2
    • Desolder the four aluminum tabs and for more information on soldering click here.
  6. Replacing an Atari Capacitor: stap 6, afbeelding 1 van 1
    • Remove the aluminum back protector to gain access to the C10 capacitor.
  7. Replacing an Atari Capacitor: stap 7, afbeelding 1 van 2 Replacing an Atari Capacitor: stap 7, afbeelding 2 van 2
    • Desolder the C10 capacitor.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Lopez
443 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-42, Maness Winter 2014 Lid van Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 4,960
